I have a 13 month old Mercruiser factory "Remanufactured" TKS Engine part number 865108RB9 when I plug it in to Mercs website it does'nt recognize it...looking for electrical schematic...
Ran okay yesterday in the morning but when I went to restart it...it seemed like it flooded and then would not fire and did not start. Today it started this morning and ran only on a few cylinders lots of blue smoke. Removed plugs most were badly fouled with carbon. With plug wire attached tested spark by holding the cleanest plug against a clean bolt on the exhaust manifold. Spark was intermitant and yellow.
Voltage to the coil dropped to about 10 volts during cranking. Checked coil resistance across low voltage posts .5 to .3 ohms. Infinite resistance between low voltage coil posts and high voltage output female plug. Checked coil to distributor cap high voltage wire reads infinite resistance... on my fluke 324 meter.
Choke plates did not open...could not disengage them...
My last boat I repowered with EFI wish I had with this...not a fan so far of TKS.
Please let me know how you think I should proceed to troubleshoot this issue.
Thanks for your input,
Tom
Tom
