Gibbles
- Nov 14, 2009
- 2,046
Well I recently bought a new to me boat, and I got one with a crack in the block!
what I have is a 1994 4.3lx with the 4-barrel carb.
Much of the details I'm still not sure about, however I'm weighing the idea of upgrading to actual Vortech heads, and the Edelbrock manifold...
I see many short block and long block options if I were to buy one already rebuilt, or just to buy a truck engine and rebuild it.
So, I guess my question is,
Are there any compatibility issues with the alpha 1 gen 2 out drive, or other things like if I decide to run the current cylinder heads on the newer block?
One thing I'm looking at is a block from 1997 - 2003 from a donor S10, or just a short block from an ebay seller (where I would go through that thing with a fine-tooth comb)
I'm assuming the bell housing and engine mounts will be the typical GM product and have a nice solid standard throughout the years?
I did read/skim over this: https://forums.iboats.com/threads/1990-mercruiser-4-3-same-as.769899/
And it almost sounds like I might be better off picking up a later donor engine?
Or at least plan on replacing the front cover?
