I have a Mercruiser 4.3LX 4bbl I/O. It recently developed a problem of starting right up and running great for about 30 seconds then dropping out. You can start it and set the throttle at 1500 rpm and it will hold steady there for 20-30 seconds, then the rpm will slowly drop until the motor stalls. You then have to pump the throttle while starting to get it to start again, but it will only run for a few seconds.
I have checked and cleaned the fuel screen at the carb, manual fuel pump (no splits in the diaphrams), breather tube from the carb to the bottom of the fuel pump. I had rebuilt the carb a few years ago so all of that should be OK. Would the float be sticking or should I check the coil or electrical system. Any help would be greatly appreciated. Thanks!
