I bought a boat with a MerCruiser 470 in it, and I am in the process of getting all the gauges wired up.
My volts gauge is working, and the RPM's only work when it's "cranking". I'm pretty sure they worked the other day just fine, but I don't know what might have happened.
What I need:
Can someone post a picture or describe where to put the wire from the tach gauge on the engine?
A picture for the temperature gauge and oil pressure gauge wires (where does it go on the engine)...
All my gauges have power (no lights apparently), but most just don't "work". Someone wired this boat in the most jacked up way possible. Colors on wires at one end are different from the other end.... If it goes into a harness, you just can't tell what wire is what, so I'm hoping to get these answers and re-wire it myself.
Thanks a lot!
What I need:
Thanks a lot!
