Engine: Mercruiser 5.0 MPI year 2010
Sterndrive: Alpha one gen. 2
Gauge: Merc. Monitor
Water inlet: Only from the bottom of the boat through raw water pump. No impeller in the drive
Cooling: Closed cooling
First observation
Steady alarm when increasing RPM. Alarm turns off when reducing RPM. That went on for about 10 min. After that - no alarm and I did a trip for about 2 hours mixed speed. Temperature okay.
Next observations
I did a diagnose with my Rinda tool, and the alarm was about Low Water Pressure, Overheating and Guardian Mode. Water Pressure readings is 0.14 psi, which is to low.
Last observation
At idle the Water Pressure is at 0.00 psi on the Merc. Monitor
Then, the question is: Since I have had no problems with cooling, do you expect the Water Pressure sensor to be faulty?
Or would you change the impeller in the water pump?
Or maybe something else?
Regards
Thomas
First observation
Next observations
Last observation
Regards
Thomas
