Mercruiser 5.0LX Rochester 4MV carburetor over fueling. ESN OF066511
Uncle Whitey
The clip orientation on the needle valve is super important. Some people (including Cliff) say you can ditch the clip altogether. I'd rather have no clip than an improperly oriented clip.
If you're buying a rebuild kit from Cliff's (which I do recommend), you should also buy his book. Also, this thread is a good reference. I recommend pulling the idle tubes so you can clean under them if you haven't done so before. Trash builds up there and can cause issues. You can buy new idle tubes from Cliff if needed. If you're a glutton for reading carburetor manuals, Rochester Carburetors by Doug Roe is very detailed also.
I'm actually going through the same exact thing right now with my QJ - flooding at idle. I'm adding a fuel pressure gauge to check out the pump, and also doing another rebuild with Cliff's parts.
I did get a call back from Cliff, I’d definitely use the guy in the future! Wish I knew of him before, I could have stopped the nonsense if I just pulled and sent to him in the first place.
Uncle Whitey
Installed the rebuilt carburetor, still kept the fuel pressure regulator inline. Started the boat, ran good. No over fueling, stayed at idle and ran until the temp gauge came up. Changed the engine oil, due to the over fueling, changed once more due to the oil still smelling like fuel. But I will take it out on the water tomorrow for the real test!
todhunter
Canoeist
Nice! I'm hoping to put mine together this week and see how it runs. Which regulator did you use? I'm adding a gauge for now, and if needed will add a regulator.
Uncle Whitey
I bought an easy adjustable regulator from Napa, can’t remember the name off hand. But with the carburetor gone through from “The carburetor shop” here in Denver. It runs like a champ now! So happy to be done with the maintenance! No I can go enjoy the boat!!!!
