Mercruiser 5.7 MAG MPI Water Pressure Sensor & Oil Pressure Sensor Interchange/Alternatives + 4 in 1 gauge not showing speed and oil pressure
mckaras
No idea, but I would not buy anything like this on ebay without a blue ribbon guarantee
Understood, I'll have to just source someone to repair it. Seller has a return window open for 15-30 days so I will be good if it ends up not working out.
In regards to the pitot hole on the Bravo drive how far does the wire or drill bit need to go? I have the earlier generation bravo and the wire goes in an inch or two more on it than the 09 Bravo I have.
It wasn't clogged up in the first 3 or so inches. I'm still getting hardly any air coming out and needle on the gauge doesn't even budge under light air pressure. Is it possible to clean out that 90 degree elbow in the pitot passage without dropping the lower? I've tried using an airgun with a rubber tip and then thinner wire to probe it up from the top side and bottom and still no luck blowing it out. Some minor water droplets but nothing more.
Fun Times
Any of you guys know if there's a place that repairs these smartcraft gauges?
Check with gauge saver as they tend to list the smart craft gauges...I believe there's another company or 2 out there that repair these gauges as well. Just have to do a deeper online search to find them if i recall seeing that correctly. Gauge save just comes to mind on the quick plus past members seemed to had good success with them... https://gaugesaver.com/product-category/mercury-electronics-restoration-services/
I also replaced the pitot sensor and blew compressed air into the connected sensor, needle did not even budge on the speedo whatsoever... I'm assuming the gauge is faulty unless I did it incorrectly. Pitot tube itself isn't blocked, I blew air through it. Luckily I found the correct gauge for the speedo in stock.
The code I'm still getting is 451-25. Pitot pressure/The input circuit for the sensor is below the valid limit
So, the wiring harness is connected to the sensor and the sensor is mounted on your boat?
If you can't clear the speedo hole in the drive unit housing, then yes you may have to pull off the lower housing to power wash/clean the debris out better...Could be small rocks in there too. Blow both up and down many times to maybe rock something loose and maybe a vacuum on one side while high air pressure on the other side... Maybe even try water pressure too both ways before pulling the lower housing...
D&D speedometer in the twin cities and speedometer service co in Milwaukee both repair gauges
mckaras
I've dealt with gaugesaver in the past and unfortunately they don't have a way to fix these since they cannot power them on and also do not have the parts. I might have some luck with Teleflex or the other manufacturer for the gauge. Otherwise I would've replaced it with another if there was one that would fit the hole.
I read another forum and they mentioned that the sensor is not included on my boat hence the code that pops up for it. The sensor I have is a water sensor that's attached via a tube to the power steering rack. I don't have any pitot sensor I've seen since the pitot tube goes directly back to my gauge.
I tried using brake cleaner to blow out the hole both sides and still to no avail. I'll just pull the lower and clean it out that way to avoid crawling underneath the boat and expedite the process. I spent 2 hours trying to clean it out.
