I've searched tons of threads and can't seem to find exactly what I'm looking for .
I have a mercruiser 5.7l 350 with thunderbolt ignition and alpha drive , with a 2 barrel carb in a 1996 21' Marada open bow.
Starting off last season I decided to do a carb rebuild due to some rough running early season , and wanted some better performance / fuel economy and figured on a 20 year old boat it wouldn't be a bad idea .
After the rebuild I was have intermittent running issues that seemed to result in sputtering , popping then shutting down, it would eventually restart after letting it sit . When the boat was running it ran fine and strong until this occurred . I basically ended up chasing my tail and replacing about everything within reason that I could with no improvement . Towards the end of the season the boat ran consistently just slow, about 300 rpm lower that it did all season . This was after I repropped the boat to get the rps where they should be, prior to this I ran 3500rpm across the board
The list of parts are as follows :
Carb rebuild
New alternator
New battery
New cap and rotor
New plug wires including to coil
New coil
New fuel/water separator
New tank pickup line
Checked and cleaned tank vent
Installed online fuel gauge to check fuel pressure (checked out fine )
Adjusted the shift cables which would rule out the shift interrupter because I was having that issue prior to adjustment
Cleaned spark arrestor
New starter (don't think that's relevant )
Attempted to replace the ignition sensor under the cap, but when it was replaced the boat ran terrible and wouldn't rev past maybe 2000rpm
Checked the timing and seemed fine
So far the only thing I have done this season is ran a compression test on all cylinders getting 150psi on all but #6 which was 142
So I guess my question is can anyone point me in a direction of something I haven't done? My thoughts are either a carb related issue or something related to the new ignition sensor not working / making the boat run worse
Carb rebuild
New alternator
New battery
New cap and rotor
New coil
