- Jul 23, 2011
- 51,243
simple test done with a piston stop toolTo OP- might be worth verifying balancer hasn't slipped verify indicated TDC is actually tdc ...
if you dont have a piston stop tool, make one: take an old spark plug and knock the electrode out of it, then weld a nut on it and use a bolt with a rounded end. plenty of how-too's on the web.
using the piston stop tool turn the engine by hand (from the belts or from the flywheel, never from the crank bolt) one way until the piston just kisses the tool. mark the damper with a pen. turn the engine back the other way by hand until it kisses the tool. the damper 0 mark should be directly in between.
