1995 Mercruiser 5.7L Alpha One with 406 hours of use, approx 15 hours of use this season with no problems.
1. Took boat to the lake and it would not start. Thought it might be a dead battery; so another gentleman hooked me up with a jump and the starter would only click and the engine would not turn over. Bad starter I thought.
2. Pulled boat out, took it home and shopped for a new starter. 200 bucks later and with a new WPS Starter, installed new starter and boat starts up in driveway, multiple times with no problems, engine sounds great. I grin with satisfaction knowing that I've repaired something myself.
3. Take boat to lake again the next day after installing the new starter, (yes, I did use all the new hardware that came with the new starter.) Attempted to start the boat and hear a bad noise come from the starter. Pull boat out of water and go home again without a great day on the lake. I grimace with the knowledge that I have to relay the news to my wife that I've not fixed anything and spent 200 bucks for nothing.
4. Pull out new WPS starter and find the nose cone as cracked off the housing of the starter. Go to marine store and demand money back as promised for this WPS starter, after much belly aching, get money back. I grin knowing that I now have my 200 bucks back, yet frown knowing that I still have a problem with starting my boat.
5. For ****s and grins I install "old starter" and boat starts up like she's just off the show room floor. Again, multiple start attempts are very successful in the driveway with the garden hose attached.
5b. I also checked the oil dipstick to find the oil level about 1-2 quarts ABOVE the FULL line, however oil does not appear white.
6. I have not tried to take the boat to the lake since installing the "old" starter.
As I had to go out of town, have not had the opportunity to pull the spark plugs out and check for water in cylinders. My understanding however, is that hydrolocking would not allow the engine to start at all. Is that true? Or would an engine that hydrolocks still be able to start? Engine seems to run fine when it's started, sounds wonderful in the driveway, unfortunately the kids complain when I try to convince them to use their imaginations as I hook up the tube to my wonderfully running driveway boat.
What is going on here? I plan to pull the spark plugs when I get home in a day or two. If it's not hydrolocking do I need to pull the engine and examine the flywheel? Seems that flywheels dont just go bad to me. Am I wrong? Why is there so much oil in the engine? I will drain the oil to a more appropriate level, I assumed the mechanic would have put the proper amount of oil in when he changed the oil at the end of last season. I also checked it at the start of this season and don't believe it was as full as it is now.
