This is followup to a topic I started about a year ago:
You can read the old post here
http://forums.iboats.com/forum/engi...568-mercruiser-twin-inboards-backfire-stumble
A quick overview...
Twin Mercruiser 5.7l's of 1997 vintage that have adjacent serial numbers, 0Kxxxxxx. 4bbl Weber carbs with thunderbolt V knock sensor ignition with full fresh water cooling system. There's about 350 hours on these engines and have been maintained with Mercruiser parts.
After 40 minutes up on plane around 3200 rpm, port engine will pop/backfire once out of the blue. Usually a single event, but once this begins, it will become more frequent in about a minute or two to the point of rough running forcing us to run at 1200-1500 rpm to keep the stumbling under control. Shutting the engine down for 10 minutes allows it to run perfectly again for another 20-ish minutes, then same cycle. Starboard engine will begin to "run crappy" too at about the same time, however, not so much backfire.
This occurs enough to not trust the boat for any kind of extended trip.
Per previous post, I replaced pretty much everything in the ignition system. Wisdom from the forum is it had to be fuel related, which made sense.
Real quick:
Good compression all cylinders.
New ignition wires, plugs, cap, rotor, sensor thing in distributor.
Not related to this problem, also new risers, exhaust manifolds, fresh water heat exchangers.
Rebuilt the carbs. Found junk in carbs, so had tanks pumped and cleaned. New fuel hoses, new fuel filters, new gas. This had to be it.
And, the problem persists. Completely baffled, and dejected.
The ignition coils are the only things not replaced. How do ignition coils fail? Can they fail only when hot?
Other ideas welcome.
A quick overview...
Real quick:
