lucky7's
- Jul 9, 2008
- 74
Guys need some help here as I am stumped. I have a 2002 Mercruiser 6.2 mpi serial #om300000. The problem is that I'm not getting 12v to the coil. I've tested the main power relay and its good. Also checked tach wiring and harness connectors. Whats next crank position sensor or ecm? Should I jump 12v to the coil and see if it cranks? When looking down at the coil pins which pins are 12v +-? Any ideas would be helpful. Thx!!
