Help Please,
I have a Mercruiser 6.2L 383 MAG Bravo II, Runs Rough, Guardian activated, Won't go above 3600RPM, The engine dies when throttle dropped to an idle after bringing up the RPM for a short period of time. I have it on a 29 foot commercial fishing boat. It ran fine last year, started acting up after 3 days this year. We were running on step, and the power dropped and brought us to a slow trot.
I had the 2 back to back Racor Filters with 2 micron filter changed, the Engine fuel filter changed. Checked fuel coming out of the fuel tank, Clear, clean. I also changed the High pressure Fuel pump. Replaced the High Pressure fuel pump regulator. It still is having the problem. Seems to shake a little. Changed the Distributor, After doing so it went to 3800RPM.
Unplugged the power to the low pressure fuel pump, felt the pump, then compared to when it was plugged in. It seems to be pumping. Also did this for the High pressure pump, seems to be pumping. Though multiple sources *Mechanics* say that we might have gotten a faulty new High pressure fuel pump. They recommend replacing it again.
We had a pressure gauge attached to see how much PSI the fuel was giving, was told it should hold steady at 38 to 40PSI. However, when we are running the motor at a idle it is bouncing anywhere from 25 to 35PSI. Sometimes it'll bounce to 40 PSI with RPM over a 1000.
We also bought a TechMate Pro Dyanostic tool for the Engine. Here are the results it remembered (Freeze Frame) when Guardian was activated.
Engine Speed 1320
Coolant Temp 125
Manifold Pres. 13.6
Barometric Pr. 14.5
Manifold Air Te. 116
Throttle Pct 30.0
Demand 30.0
Oil Level 0.0
Block Pressure 0.5
Battery Volts 14.1
Available Pow. 4
Engine Load 26.7
Engine Run Tim 265.1
fuel Per Cyl 0.0
Engine State RUN
Shift Position IN GEAR
Trim Position 0.0
Fuel Level 1 0.0
Port Tab Pos 0.0
Stbd Tab Pos 0.0
Lake/Sea Temp 0.0
Ray Boat Speed 0
Main Pwr RlyRe YES
Fault Freq Cou 2
Some of the Freeze Frame lists available other than Engine Guardian,
9 Engine Guardian
19 Maximum RPM Exceeded *Testing*
22 Warning Horn Out
75 Fuel Level 1 Ci....
94 Pilot Pressure
Any idea's where to check next?
Engine Speed 1320
Coolant Temp 125
Manifold Pres. 13.6
Barometric Pr. 14.5
Throttle Pct 30.0
Demand 30.0
Oil Level 0.0
Block Pressure 0.5
Battery Volts 14.1
Available Pow. 4
Engine Load 26.7
fuel Per Cyl 0.0
Engine State RUN
Trim Position 0.0
Fuel Level 1 0.0
Port Tab Pos 0.0
Stbd Tab Pos 0.0
Lake/Sea Temp 0.0
Ray Boat Speed 0
Main Pwr RlyRe YES
Fault Freq Cou 2
9 Engine Guardian
22 Warning Horn Out
94 Pilot Pressure
