- Apr 17, 2002
- 71,433
Ok,..... Then cutting the head off, isn't an option, unless you pull the motor 1st,.....Thanks Bondo, but it's not the bolt you can see it's the one on the manifold to the head that you can not see. The elbow to manifold joint was leaking right at bolt the arrow is pointing to and ran down and corroded manifold bolt. I do not think the bolt is frozen in the threads as all others came out clean. Just can get a bite on the bolt head. I ordered some extracting sockets for stripped bolt heads they will be here later.
Headed there in a few minuets with an arsenal of tools, with any luck it will be off before lunch. I will post an update later.
Mike
If the head is cut off, the manifold still won't have enough space to slide of the remainder of the bolt,.....
It looks to be so tight, that weldin' a nut to the bolt head is also impossible,....
Good Luck,...... yer gonna need it,......
