MerCruiser 888 Serial #
c384id70
:(I have a 1974 Reniell with a replaced 302 Ford V8 and who ever changed the motors didn't transfer the motor tag to tell me what I need to know when buying parts.
The outdrive serial number is 3784434 as close as I can read it. Is this the same number as the one that should be on the motor? Is there any other places to look for the right number or a way from what I have to properly identify what I have?
haulnazz15
Re: MerCruiser 888 Serial #
I'm not sure what you mean. The engine serial number is stamped on the block. It's a Ford 302, which was the stock engine mated to an 888 drive (1.50 ratio). Most all of the parts for the drive are consistent with the Mercruiser Type I "pre-alpha" drives and Alpha I drives. The engine doesn't have any Mercruiser specific stuff aside from marinized USCG stuff (alternator, fuel pump, carb, distributor, starter).
Ayuh,.... Welcome Aboard,... What parts in particular,..??
Post some pictures, 'n We'll help ya figure it out...
