Mercruiser alpha lifting point
H20Rat
Quick question for the experts... I have my outdrive already off for winter, and am looking for an over-winter storage option that ISN'T on my wood stand.
On the top cap on the upper unit, there is a useless little loop through the cap. Is that intended to be used as a lifting point? (and if not, i'm really curious, what is it for?)
(on the back of this...)
Bt Doctur
tie a strong cord thru it or bend a large landscape nail into an "S"
Scott06
You can hang it from there, I usually lay mine on the floor under the trailer can’t get damaged if it’s already on the ground
The drive weighs the same as 2 cases of beer. I used to just pick it up and put on the work bench
"(and if not, i'm really curious, what is it for?)"
Here's what mine is used for on a 1976 MC-1. I've been assuming this was a common feature back then, but don't know for sure.
H20Rat
I'm a big guy, I can probably single arm curl a drive... :)
It's in a storage shop that is jam packed for winter storage, and doesn't have a work bench. Hanging the drive is the best option, assuming that hole was meant for it.
alldodge
Picked Alpha's and Bravo's up using the little slot without issue.
