Weathersbytaylor
- Mar 12, 2017
- 19
Hello all, I’ve got a mercruiser 3.0/alpha one setup that’s been making a knocking noise. The engine is brand new and when I was installing the outdrive it was extremely difficult to install. My noise is only noticeable at idle and appears to be coming from directly behind the engine. I’ve also developed a leak from the rear main seal. Is it possible that an incorrectly adjusted engine angle could cause stress on the flywheel and cause a leak and a knock? I’m confident the engine internals aren’t the issue. Noise can’t be heard from outside the boat. Maybe a gimble ?
