trooper1954
- Jun 29, 2018
- 76
Hi all,
Brand new here and fairly new to boating. Just inherited a 1990 searay 16' with a 3.0 mercruiser engine and alpha one sterndrive. While winterising, I checked the power steering reservoir and found a creamy pink frothy situation in there. I know its water, but my question is where did it come from? The bilge is spotless and dry and shows no sign of ATF ( which I'm thinking was used and is creating the pink look) I'm wondering if perhaps because of lack of use, a seal in the one of the hydraulic cylinders has dryed out causing the water to get in?
I know I have to drain the system, but as I said I'm fairly new to baoting, and would like some help with this process. Do I disconnect the lines at the cylinders and then turn the wheel full laft then full right until I see fresh new fluid appearing? Would this be good enough to rid the system of all the water?
Any and all help would be appreciated.
Thanks.
Thanks.
