Re: Mercruiser Alpha1 conversion form carb to throttle body
Thank you all for your responses.
The boat is the same size as the last one, weight could be a factor, it is much faster 55 mph last boat about 40 mph, the carb is an Edelbrock, boat was built in 1994, it is a custom boat out of cal, so I think they put on some custom stuff like the carb. I do not know on the spark plugs I will have to check. Is there a color that you have found to be better than others?
It smells rich like raw fuel more that I would expect, does anyone have a good routine for adjusting the idle mixture screws? It is a fun boat I would just love to get the fuel consumption down a little. We do run the boat at 3/4 throttle however we wake board and tube and so full throttle to get out and up. the prop seems to be pitched a little to the top end so I am going to get a backup that is pitched lower for more hole shot and see if that helps a little any thought on that.
