I have a 1978 165 hp Mercruiser I/0 that is very difficult to start when hot. It fires up just fine cold, runs fine hot whether its pulling the kids on skis or trolling for hours at low speeds. But if I shut it off and then try to restart after a few minutes, it just cranks and cranks. I can usually get it started after removing the flame arrestor and cranking it with throttle wide open. But sometimes to a point of almost running the battery down. Coil, distributor, points, condenser are all new. Carburetor was just rebuilt even though fuel is clearly squirting into throttle chamber. Compression ranges from 55 to 65 psi. The only thing I haven't changed is the fuel pump, but I've ruled that out because it runs fine...once it's started. What am I missing? Does anyone have any ideas?
This is really frustrating. I just want this to start reliably.
