Bt Doctur
- Aug 29, 2004
- 19,442
the left side ,front to back are 2,4,6,8. the right side front to back are 1,3,5,7
clean or rusty looking water? Could still be salvageable . remove the manifold hoses and the block drains. drain everything first.
Dry the plugs/ replace the plugs and fire the motor as soon as possible to dry it out.you can run it for about a minute or two. let cool and fog the motor until it stalls.
this can be done without water.
To test the block, remove the spark plugs again, remove the large hose from the therm housing .the hose that runs from the circ pump to the therm housing. using a hose , fill the large hose until it comes out the therm housing.Watch the hose to see if the water level drops or wate begins to exit a spark plug hole.
pm`ing a cell
pm`ing a cell
