I have A 1986 glass master with a four cylinder Mercruiser. Tilt and trim was working fine after I changed 1 silenoid then it wouldn't work. I checked the fuse and everything was in order. When I jump the solenoid directly to the pump it works fine. I don't know if it's the connection in the throttle handle? Or somebody suggested that it could be the 3-wire rubber boot connection tends to go bad there. Any help would be greatly appreciated, thank you!
