Mercruiser Lower Unit ??????
mmajor97
I have 2 Mercruiser lower units (I am guessing) and I would like to know if anybody can tell me if they are interchangable or not. The numbers I got off them are:
1623-8266
1623-5412
I have searched the internet everywhere to find something on either one of those. Hope you guys are more resourceful than I am! Thanks a million for any help/advise you might be able to give.
mmajor97
Re: Mercruiser Lower Unit ??????
Unfortunately I do not have any way to get you any pics. The kids sent the wifes camera on a toilet adventure.
mmajor97
Here are a couple pics of the two lower units I have. everything is identical except the back of the unit where one is tapered off and the other is squared off. The vertical drive shafts are both the same with the o-ring groove and the push pin. The upper unit I have is squared off at the back and matches up with the lower in the picture but the seals are bad in it and I would like to use the other one that is tapered off. Please help if you can!
Ayuh,.... They'll interchange,... No problem...
mmajor97
That just made my day! Thank you very much for your time and wisdom!
soldier05354
1623-8266s will not superexceed to anything. Mercury Part Number: 1623-5356A4 is the real part number and I know this from experience of replacing cases. that lower gear case fits MerCruiser 1 thru R pre alpha units 120/140, 470/485, 160, 165, 888, 225-s, 233, 896/226/260, 250, r , is all the units that hosing applies too. the gear ratio is diffrent though between these units but use the same casing. the sierra part number is 18-2402. the FOWARD GEAR BEARING BORE SIZE is 3.4985-3.50 IN I.D. on this cassing.
http://www.marinepartshouse.com/mer...nt-sterndrives-complete-c-23_25_1850_163.html
go to this site to see the aplication guide. Marine Parts House calls this lower gear case housing a 17000There you can also see the serial no application.
