I have a 2005 MAG 350 MPI engine with a Bravo 3 outdrive both with about 350 hours on them. This is on a Bayliner 275. Late this summer season I started experiencing performance issues. I found the boat would not get on plane and WOT was about 3200RPM. At first I thought the outdrive was not trimming properly but I did an compression test and discovered one cylinder has no compression and another cylinder on the same bank only has 65 PSI - the remaining cylinders have 150-190PSI. I took a look in the 0 compression cylinder with an inexpensive endoscope (pictures attached). There seems to be heavy carbon buildup - especially on the back of the valves. There also appears to be some rust? on the piston head. Fortunately the cylinder walls looked ok. I'm wondering if one or both of the valves are no longer seating properly? I also wonder if I have a gasket leak where cooling water is getting into the cylinder?
I'm curious as to what my next steps should be - I want to determine if there are any issues with the block or if the issue is just in the heads. Should I do a leak down test and try to determine where the issue(s) is?
Thanks,
Gil
Thanks,
Gil
