Mercruiser out drive compatibility
Ghg
Is there any difference between the outdrives of 1967 Mercruiser 4 cylinder and same year Mercruiser 6 cylinder? Any gear ratio difference?
alldodge
There is no difference other then the possibility of a different ratio
Most will be different ratios if installed on the same model boat, but if different boats can have different ratios
Ayuh,...... Welcome Aboard,.... The housings should be the same,....
The gear ratios will be different though,.....
The I-4 should be 1,98:1,....
The I-6 could be 1.84:1, or 1.65:1,......
Going from I 6 to I 4
Ayuh,.... Then you'll need to drop some prop pitch,.....
Donno how much though, depends on which ratio the drive is,.....
What prop pitch were you running on the I-4, when it had the proper ratio,..??
Hopefully, you'll be able to find a prop small enough,.....
Scott06
If he is going from a 6 cylinder to a 4 cylinder drive doesn't he need to increase pitch?
alldodge
It had 23 stamped on the prop, is that the pitch?
Might be, need to look further
No, would need to decrease pitch
Might even think about not doing it depending on what boat it is. If the boat is heavy for a 6cyl then it will be a dog with a 4cyl, even with less pitch
alldodge
Is there a way to determine the ratio?
Remove drive and prop.
Mark prop shaft and drive shaft (grease pencil or marker)
With drive in forward or reverse rotate drive shaft 10 revolutions while also counting prop shaft rotations.
Divide prop into drive
Exp 10/5= 2.0
10/5.5= 1.81
Scott06
I might be getting stupid but I thought he was not switching engines but rather drives - going from a 6 cylinder drive (1.65 or 1.81) to a 4 cyl drive (1.98) so increasing the gear reduction
alldodge
Using Bondos post
He will have a 1.84 or 1.65 drive
Installing a 4cyl means less power to spin prop that fast. The 4cyl would have a 1.98
The 1.98 woukd spin prop slower. So needs to reduce pitch to compensate
Using Bondos post
Oh boy,..... Now I'm confused,.....
I read Ghg's post to say, he's going to a taller geared drive, with the smaller motor,....
Maybe I missed the boat here,.....
Ghg, What motor do you have,..??..??
Ghg, Which drive do you intend to run,..??..??
Ghg
I’m not switching from a 4 cylinder to 6 cylinder engine, I’m considering buying a outdrive that is on a 6 cylinder for my 4 cylinder motor, same year engines
Scott06
Ok that’s what I was getting at , assuming the original prop hit the correct wot rpm you will need a higher pitch prop to account for the higher gear reduction in the 4 cyl drive.
as an example I repowered my current boat.it originally had a 4.3 V6 with a 1.81 ratio drive. I upgraded to a 5.0 V8 that from the factory would have had a 1.62 ratio drive. I kept the 1.81 with the bigger engine went from a 19” to 21” pitch prop and it worked just fine. You will need to do the same and step up in pitch to make it work
