Johnson110
- Dec 31, 2003
- 640
I checked my 3 pin connector at the trim motor pulled it apart and found corrosion on the pin cleaned it off and it started to work then it died again, I jumped the red terminal to the up and down solenoids and they worked, I am thinking that this round connector is making a bad to no good connection. Can I disconnect cut out the connector and put a water proof 3 pin automotive connector in it's place? The trim tilt would sometimes work and not, it could be up or down that would stop working!
