mercruiser v6 4.3 water in oil
jenny
Help! I had a water oil mixture in the engine. I pulled the oil plug and water came pouring out. When it was done draining water, it drained a water and oil mixture. I checked the compression, and the compression was about 140 for each cylinder.
Re: mercruiser v6 4.3 water in oil
Ayuh,... If this is the 1st run of the year,...
I'm guessin' you've got a Cracked Block, probably from improper winterization...
jenny
This is the second time taking it out, but the first time out was only for an hour before it died. I replaced the cap and rotor and it started up. So basically, this was the first time taking it out for a significant period of time. How can you tell if it is a cracked block?
Ayuh,... You have to isolate the blocks cooling passages by disconnecting hoses, plugging, etc, then pressurize with air, about 15psi...
You Hear the leak, then follow the sound...
When/ how often was the oil level Checked,..??
jenny
Have you ever heard of lock n stitch? If so, what is you thoughts on it.
Bt Doctur
If you think you see a crack or leakage please tell us.
Freeze cracking happen internally as well as externally, cant "stitch" the inside ones.
Ayuh,... On an antique Unreplacable block,... Maybe...
On your 4.3l,... No way,... They're a dime a dozen...
And,...
It takes some mass to support lock, 'n stitching...
Where you block is probably cracked, the distortion will be unacceptable...
Welding, or epoxy won't work either on the Oil side...
jenny
Every time before I took it out, the oil was checked.
jenny
There is also water oil mixture on top of the engine. I don't know if this helps or not.
Nope,... Still sounds like a Cracked Block...
Who winterized it,..??
jenny
I did. But I started it in April and then it froze again in May and June.
Ayuh,... There ya go,... Now ya need a new motor... Shoulda atleast Drained it...
jenny
A freeze plug was popped off when I took it out the first time.
Bt Doctur
trouble is it cracked internally before it pushed the core plug out,.
just for the heck of it keep running it until it dies! then get a replacement engine. just so you know your mercruiser 4.3 is just a regular old chevy 4.3
jenny
Thank you everyone for you help. It looks like I am looking for a new motor now.
jenny
I just found a used engine. How do I know if it is still a good engine? It is already taken out of the boat.
Bt Doctur
portable tank,hook up a battery, jumper from the +batt to the + coil,jump starter.add water.
fossill
They are not freeze plugs. A common misconception. They are casting plugs used to cover the holes where the sand is extracted from the block when it is cast at the manufacturing plant. Those plugs have nothing to do with offering any kind of freeze protection.
