Hello,
I was wondering if someone can help me out with an unusual problem.
I have a 1986 4.3 V6 Alpha one 205hp. It has a 4 barrel rochester with thunderbolt ignition. It was rebuilt about 5 years ago.
It idles well (purs like a kitten)with no issues at home in the drive on the muffs. However on the boat ramp in the water and on the water it will not idle or idles rough with lots of black smoke coming from rocker covers via the blowby valve hole, it will cut the engine due to fumes if engine cowl is closed, it does not use or burn any oil.
At 3200 it easily planes at 20 knots and runs well, same at 4000 rpm. There are no noises, tappet or knocking, the motor sounds good. What I have done so far:
- Compression test 140/150 psi per cylinder, no difference wet (oil).
- New plugs, leads, Cap and rotor.
- checked flapper valve (perfect)
- cleaned spark arrester
