Mercruiser water seperator
cooter2506
Should you fill the seperator with clean fuel when you put it back in or will it fill itself fast enough to not stall engine? 1998 5.0 with electric fuel pump
tommays
Re: Mercruiser water seperator
If you do not fill the filter the pump may run dry and be damaged
Tommays
cooter2506
I will just fill it to be safe. Thanks for the replys
scooter4n
Where is water separator usually located?
I have 1990 Chaperell
Thanks
RubberFrog
It has more to do with the engine than it does the brand of boat.
Coors
I always fill my fuel and oil filter when changing.
Frog, you scare me with that avatar.
cooter2506
Coors I did fill it and the engine never died on me so I will continue to fill it. Thanks for all replies
WAVENBYE2
OOOPS, I didn't prime mine when I installed the fuel/water separator, never had one til now,and followed all your advice to install one, I just thought the electric fuel pump would fill it way before it made it to the carb.:redface:>>Pat
