Mercruser 5.7 water circ pump
andy1435
Hi every one i have a 2002 trophy with a 5.7 mercruser in it and the water circ pump hase never been replaced from past owner. was wondering how often should they be replaced
Thank you
Re: Mercruser 5.7 water circ pump
Welcome Aboard,.... No reason to replace it, unless it's leakin' outa the seal behind the pulley,...
andy1435
Ok thank you replaced my risers and manifolds last year. Thought i should replace so when im on the ocean prevent problems.
Watermann
I've replaced water pumps when the vanes inside get wore down and having cooling issues but normally only when the they start leaking like Bondo says. I'm assuming your talking about the water pump on the 5.7 and not the lower unit water pump.
Pete104
I think he's talking his HOSE @ the circ pump!
There is no scheduled replacement interval for any hose on Mercruiser engines. But if you spend any time in "the brine" as Bond-O refers to it and aren't religious in flushing, you might think about changing it. Relatively cheap.
crazy charlie
I have a rule I use with every new to me used boat I have ever owned.Before it ever hits the water in my ownership I start with a new circulator pump as well as transom kit and manifolds and drive service.When in doubt...Change it out....Charlie
MikDee
Banned
Be sure to use marine parts, I believe the backplate is stainless (and that's the expensive part). Impeller is different too. maybe you can save your backplate for the new, or rebuilt pump.
achris
More fish than mountain goat
Automotive is pressed steel sheet, marine is cast brass...
MikDee
Banned
Not on my old 79' SeaRay 24ft cuddy 350/260 Mercruiser. It was SS! I would think cast brass would be a rarity? and even more expensive.
