Mercrusier 350 MAG MPI - RPM issue under a load
alldodge
ok, then change up
A 4x4 prop set of 18 = a 3x3 prop set of 20
So if you had 3x3 20Pitch you have about the same with 4x4 18Pitch
Go with a 3x3 18P
Rick Stephens
This seems all wrong. An 18 pitch is not going to be incredibly far off that you cannot get over 3400 RPM - no way. Are we sure the drive gearing is right for this boat and motor. You would need to drop down to a 12 or 11 pitch to get RPMs in proper range and that makes no sense at all.
wbas1
Originally I was able to get to at least 4K by pulling the map sensor to give it more fuel. The mechanic said nothing is wrong with the motor. He had also mentioned the props. Nothing is really making sense with this boat.
wbas1
ok, then change up
Go with a 3x3 18P
So the 4 x 3 is no good correct?
How can I tell if the original motor was a 6.2L? I still have the old block.
Measure the stroke. A stock stroke will be 3.48". A 6.2 liter will have a 3.75" stroke
Rocker arm ratio will also be 1.6:1 vs 1.5:1
wbas1
Update: I went back to the prop dealer and they are saying that with these props and motor the boat should jump out of the water. He also mentioned something else is going on with the motor that I am 1k RPMs off. I can only make about 3600 when I should at least be 4600. Well back to the drawing board.
wbas1
Question: Can any of these sensors limit power on my motor?
1: NOC Sensor
2: Gear Indicator
I reached out to the Mechanic that looked at the motor last week and he pretty much told me there is nothing wrong with the motor and he would not even know where to look next. He just did not want to be bothered.
alldodge
I would need to take the motor out correct?
Yes, so it can be put on a stand and connected to the dyno
1: NOC Sensor
2: Gear Indicator
If ECM things the motor is not in-gear it will limit RPM. That said, if this did happen there would be an alarm. So if you get beeps when key is turn to RUN then this would not be the issue
Don't recognize NOC
I haven't put my hands on it and I don't know where to go next my self. I'm here until we figure it out or you give up
wbas1
Don't recognize NOC
I meant to say Knock Sensor. As you can see this is just beating me up.
wbas1
Don't recognize NOC
I really have to say thank you for all your help. I am not giving up yet. I have a call out to the original owner to see if he can shed some light.
alldodge
The knock sensor will reduce power, but would also throw a code
wbas1
I looked for it but didn't find. Did this motor get run on the Diacom software?
Yes the mechanic that came down had the software on the laptop and we took the boat for a ride. He did not see anything abnormal. He only gave me 2 screenshots.
