nola mike
- Apr 22, 2009
- 5,830
.I'm pretty sure i have spark or at least most of the time , since it starts back up. just now and then it wont.
Well, you know you have spark when it runs. It's when it doesn't that we're concerned. Next time it isn't starting is when you want to use your spark tester. Gas shooting into the carb is from the accelerator pump--that should allow it to start (at least briefly), but doesn't tell you if you have a fuel delivery/quality problem once running. If it's running initially, your timing is at least good enough to run. Running with no load on muffs doesn't test anything. What did you find when you changed the water/fuel separator? That initial 1/2 tank might have had enough crud/water in it to gum up your carb...
