achris
More fish than mountain goat
- May 19, 2004
- 27,468
Re: Mercrusier 4.3l LX 1994 - Starter issues
Are you saying there are NO cables on the negative terminal at all?
Are the cable lugs clean? If there is a little corrosion between each lug it would display exactly as you are seeing it... Make sure all ground and power wire terminals are cleaned, with a wire brush....
If the terminals are all clean and you have the smaller red wire on the big terminal of the starter and you still have no power, connect a temporary wire from the starter terminal (same one as the red battery cable is on) to the red terminal on the circuit breaker...
Chris......
Odd indeed -
There are two small terminals on the battery - the ground is connected to the battery by a small wingnut. The larger neg terminal on the battery has nothing connected.
Chris......
