Mercrusier alpha one gen 1. New impeller, no water flow
Mrbrown7
Mercrusier 5.0 I/O alpha one gen 1. New to owning a boat. Bought a fixer upper. Got it running with muffs on and was not getting water out of exhaust. Installed new impeller still not getting water flow and no water at thermostat inlet. With lower unit off, placed hose in inlet at thermostat had good water flow coming out lower unit. Replaced impeller again along with new pump housing and still not getting water flow please help. Thanks in advance
Ayuh,..... Welcome Aboard,...... How are you feedin' it water,..?? with a hose, 'n muffs,..??
QBhoy
Send a pic of your muffs and how they fit on the drive. Some of them are just terrible and don’t work.
nola mike
Possible that the water pipe going to the gear housing isn't aligned properly. Also any air entering the system (a melted water pocket cover in the upper for example) can cause flow issues. Assuming your impeller is installed correctly
QBhoy
See if you can get the flatter and tighter fitting ones. I didn’t have too much luck with a set like yours years ago either.
Mrbrown7
Are these any good.
Ayuh,...... The drive was run, low on oil,..... time for a new one,.....
