mercrusier engine alignment
monstertails
I just have a quick question about alining a mercruser engine, I hade to replace the drive coupler and I just want to know when I am alining the drive with the alinment tool do I have the rear motor mounts tight and only loosen the front mount or are they all loose? It is an 88 3.0l with three mounts. Thanks
tpenfield
Re: mercrusier engine alignment
Rear should be fully secured . . . front loose, so you can adjust.
