got a 165 250cid need valve jobany know were to get some and need the water pump kit number it is a pre alpha 165 drive thanks
iknow how to do a valve job is and allso have the tools i just cant find the wright oneDo you know what a valve job is? You don't just order one and have it delivered. In a nutshell, you remove the head from the engine, send it to a machine shop that grinds the valves and seats with special equipment, then you re-install the head back on the engine.
Which water pump kit are you looking for? There is an impeller kit, and kits with the upper housing, some with the base.
I guess another question might be: How did you determine it needed a valve job?
pulled the head off and the vale was caked so i am going to change the valves and the piston
The rod whet throw the top of the piston after it hit the valveAyuh,.... What's a Caked valve, 'n What's wrong with the piston,..??
