I have a Mercury 110 with a TON of crankshaft end play. So I pulled the motor, split the case and it looks like the goof who owned this motor before me has replaced the crankshaft bearings with metric bearings. *** 6204 bearings to be exact. The friggen bearings slid right off the crank shaft.
So just to be sure, Mercury uses Imperial sized bearings correct ?
Also does anyone have a crank bearing kicking around that they could give me the ID and OD so I can get a replacement locally.
Looks like this is bearing i need http://www.iboats.com/GLM-21625-repl...view_id.459263
