Mercury 115hp model 82 wires pull out
Joe-Au
Just pick up mercury 115hp 82 model, don't know what these wires connect to? hope some one help, thanks in advance.
Joe-Au
Just figure out, hope this correct, connect 2 yellow wires to 2 bottom connect pin out at rectifier, red wire to + rectifier, grey to 1 of yellow connector trigger, tried to test spark, don't know, how comes no spark from 1-2-3 cylinder, but good spark on 4-5-6 cylinder, anyone help please.
There are 2 switch boxes one for 1 3 5 cylinders and one for 2 4 6 cylinders.------Your numbers ?----Could be one bad switch box.
Joe-Au
Yeah, I read some where in here, said about that, but one for odd and other for evens as you said, but mine 3 top cylinders no spark, and 3 bottom they are all good, checked wire color connection, the previous owner connected wrong from top switch box, I changed over, but still nothing happen...
opalized1
WHAT IS THIS,, IT IS THE RECTIFIER, SHOULD BE CONNECTED TO WIRES FROM STATOR UNDER FLYWHEEL, CHECK FOR 2 WIRES COMING DOWN FROM UNDER FLYWHEEL, THIS WOULD BE THE CONNECTION POINT FOR THOSE 2 WIRES, THE 2 WIRES YOU REFERENCE FROM THE TRIGGER, WHICH MEANS THE COME OUT THE SIDE OF DISTRIBUTOR, WOULD NORMAL GO TO A CONTROL BOX, THE HOT FROM THE MAIN SOCKET, I WOULD GUESS GOES TO THAT CONTROL BOX THAT APPEARS TO BE MISSING
Joe-Au
Thank mate, that's 2 yellow wires came out from stator under flywheel "sorry was mistake" connect 2 pin out rectifier, and other side rectifier signed with "+" I connected with the red/white strip from main socket to that pin
