Re: mercury 20 electrical probs
Try disconnecting the wire that runs from the terminal block to the kill switch, to be sure it isn't shorting to ground. Had that problem with my 1976 Merc 200. Bad wires on those motors. If that's not it, you'll have to dig deeper, but it is worth a quick check. By the way, if that works, you can kill the engine by choking it, then fix that wire!<br /><br />Good luck!
