I have a 2001 150hp Saltwater motor with carbs. The Water pump impeller has been replaced but the tell tale hole does not pee water at idle and it only sputters at speed. I checked the thermostats and one was closed and the other was partially opened. I removed both t-stats and the tell tale hole has a full stream but I plan to replace the t-stats and am thinking that the tell tale hole cannot be supplied by the T-stats or there would be no water visible until the engine warmed up. I know the impeller is working because water is flowing through the t-stat housings, but where else does the tell tale hole get water until the t-stats open? And am I in danger of hurting the motor if I run it without T-stats.
