wcsd106
- Mar 27, 2010
- 182
Last spring, I took my boat out for the first trip of the season and ended up sucking a small piece of twig into the carburetor for the #6 cylinder. To make a long story short, after removing the carb to get the twig out, I decided a rebuild of all 3 carbs was in order due to the fact that it had been at least 12 years since they had last been rebuilt. After rebuilding the carbs, I never got a chance to water test the boat again since I ended up moving shortly thereafter and spent the rest of the summer assisting my fiance with plans for our wedding in the fall.
Over the winter, I purchased an original Mercury Shop Manual to supplement/replace the Seloc manual I had purchased.
A few weeks ago, I got the boat back out and started getting it ready to hit the lake. Prior to putting it on the lake, I started and ran it several times on the driveway using the flushing muffs and garden hose.
The following procedures/tests were performed before putting it on the water:
1. Complete link-n-sync of the carbs/ignition. (Throttle pick up timing / WOT timing / Carb butterfly position all set to spec)
2. Spark plugs were replaced with new plugs due to their age and condition
3. Compression test was performed on all 6 cylinders. All 6 cylinders showed ~120lbs with no apparent signs of leakdown
4. Stator was tested for good measure (For the record, the Stator and both boxes were replaced about 2 years ago with new CDI Electronics brand parts)
5. Each cylinder was given a short spray of SeaFoam Deep Creep prior to the first attempt to start the engine
The engine started and idled well on the flushing muffs, so a water test was in order. I made a water test this past Sunday with poor results.
Results:
1. Engine initially had trouble starting, but once started, began idling well.
2. Throttle seemed sluggish...slow to respond to advancement of the throttle control
3. After idling out of the no wake zone, I attempted to throttle up but the engine would climb to about 2500RPM then slowly work up to 4000RPM. Boat would not plane.
4. I was by myself, so I was unable to try squeezing the primer bulb while the throttle was pegged to see if it was a fuel delivery issue.
5. Engine seemed very sluggish and seemed to lack power even when running at 4000rpm.
I returned to the launch ramp, put the boat back on the trailer and went home. I checked the fuel pump and engine fuel connector the next evening. The rubber O ring in the fuel connector was shot, so it was replaced. The fuel pump screen was slightly dirty, but was cleaned and then put back onto the engine.
I removed all 3 carbs one more time thinking that I must have not gotten them clean the first time. They didn't appear overly dirty upon inspection this evening, but they have been thoroughly cleaned again and blown out with compressed air. New gasket sets are due to arrive hopefully tomorrow and the carbs will be reassembled.
After the carbs were removed, I used an LED light to look through the intake to the reeds. They appear to be in good shape, but that is the extent of the testing I've performed on them.
When removing the carbs, I noticed that the lower side of the enricher solenoid fuel line was split (the line that runs from the enricher to carb #2 and on to carb #3. I purchased new fuel line to replace the split line this evening.
I also purchased new vacuum lines to replace the existing vacuum lines. The existing lines are still pliable, but feel brittle in spots. They are more than likely the original lines. *** Is this a good idea to replace at the moment? ***
I picked up a new fuel line connector this evening to use on an extra fuel line I have. My plans are to attempt to run the engine off of a different fuel tank to rule out any problems in the tank / fuel filter / fuel line.
Does anyone have any suggestions or comments on what could possibly be robbing my engine of power? The engine is a 1984 Mercury 200hp with WH28 carburetors.
I've always gotten good advice here, and thanks to help I received on this forum, I was able to get this boat and engine running great a few years ago. Thank you for reading.
Results:
