Mercury 225 EFI Off Shore
nottus
Will Not Start, Spins over fine. Has gas to the fuel pump.
Spark plugs are Wet, Seems to have No fire. Tried to Check that
with the plug out and grounded to the engine. I saw No spark.
Any Input on this would be nice, Thanks in advance.
nottus
rtpassini
Re: Mercury 225 EFI Off Shore
what have you all replaced to try and get spark?
also, have you checked your compression to rule that out?
JB
Do not replace stuff trying to find out what is wrong.
Get a factory Service Manual and troubleshoot your ignition system.
Faztbullet
Stop at the auto parts and get you a enclosed spark checker, check if you have spark on all 6 cylinders. If no spark check that kill switch is installed. If thats ok repost and we will go from there.
