Mercury 350 MPI shutting off
sbm371
Have a 350 MPI that shuts off at all throttle positions intermittently, started out as once in a while but now very frequently, seems to happen most going through 3500-4000 RPM but will also occur at idle speeds. it's as if you turn the key off, will start back up with no problem. Any ideas.
tpenfield
Lanyard switch becoming intermittent.
Key switch leads loose.
