Hello,
Ive just rebuilt a 1979 Mercury 7.5 two stroke. The engine needed to be rebuilt as the reed valves and oil seals were not sealing.
Im having trouble getting the engine to fire up, the stator can only be installed one way, the flywheel only fits on the shaft in one position due to the woodruff key, there is no fine adjustment. The carb has been stripped down and seems to be working fine.
The resistance on the coils is within spec but towards the low end. I have good compression, both engines have spark but will not fire.
Any suggestions on what could be wrong would be greatly appreciated
