mercury 70hp spark plug wires
_vn_
Hi, I got this 1984 70hp mercury outboard 06382231 that i need to replace spark plug wires on.
looking at the serial number i get a part number 812715a1, however this part lists 9" wire - which is not correct length.
when i spoke with mercury they suggested that perhaps wires on my engine are ran in non oem way, but i looked at few videos on youtube and looks like mine are ran same way that others.
my wires are at least 20" long, has anyone had this problem and found a solution?
thanks!
I do not see a 70 hp model listed for 84 year.----Pictures of your motor ?-----Is the model an 0G382231 perhaps ?
_vn_
here you go, sorry i don't have one with cowling on
I believe your motor is an 83 model.-----You are looking at the wrong parts diagram I believe !
_vn_
i searched by a serial number, in mercury marine parts catalog
What site lists that part # at 9" long ?--------813715A1 might be 9" long.
Post # 1 mentions 812715------and there is 813715.----I give up.
roscoe
You have a 1983 model.
That "0" doesn't belong at the front of your serial number, seven digits only.
[h=1]70 (3 CYL.) - 5579017 THRU 6428680[/h] Mercury-Mercruiser 84-813715A1 LEAD WIRE
Google it, or take it to your Merc dealer.
Unfortunately, iboats doesn't carry it.
2484-813715A1 LEAD ASSEMBLY, SPARK PLUG93475A25SS/ACT
$28.50$27.79
mercruiserparts dot com/813715a1-cable-assy-ign
It is now a cut to length wire, so it fits many models.
GA_Boater
Yes - I made my own with Packard 440 wire. It has a copper core and 7MM insulation. BWD also makes 7MM copper core wire. It's less than a buck a foot at your local auto parts store - Check the national AP store sites.
_vn_
that was a typo, however if you quit giving up and google 813715 you will find this
_vn_
$28.50$27.79
when i tried to search in parts catalog for my serial without 0 in front - search didn't pull up any results, after that i called mercruiser and they told me to put 0 in front of m serial.
and still if you take what you pasted and google it - u will get same 9" cable
_vn_
there is one more thing left, i spoke with sierra and they have 18-5229-9-1 that might fit :)
roscoe
Thats because the Mercury search system only works with newer serial numbers.
Here, mercruiserparts.com/813715a1-cable-assy-ign
cut to length.
