mercury blackmax 150 power/wot problems
cam1399
And bottom moved to the top? There is a fitting on the bottom of the bottom carb. I believe that’s where the primer goes?
cam1399
I have primer lines going into 2 places on the top carburetor right now. Bottom left and top on the tee
cam1399
I’m almost certain it’s fixed. I can adjust idle and it throttles very easy now. My bottom carburetor had the primer fitting on it and it was routed to the middle bleed valve. I moved carburetor to the correct position. And put that one into the primer solenoid. Then routed that bleed valve to the air box.
The air box line was routed to the tube coming out of the lower unit. Is that the speedometer?
But anyway I appreciate all of you guys for your help! I will test it on the water but is has never ran like that
