aussiejake
- May 19, 2010
- 41
I have a 2006 Merc EFI 2 stroke that seems to be running too cold causing it to run rich and foul plugs.
The sea water temp is 58 degrees
Engine Idles up to 147 degrees quickly..so thermostats are working and I have also checked them in a pot.
Engine Drops to 81 degrees once over 1000 rpm. Will stay on 81 even at WOT. If I drop the RPM back to 3500 rpm a plug will foul.
Im thinking of either putting a restrictor in the hose from the block to the poppet or a heavier spring in the poppet valve.
What do you guys think.
cheers,
Jake.
cheers,
Jake.
