Craigs1904, that's not exactly a schematic. that just shows one small section of the wiring off of one of your packs and that picture is only a section of one of your terminal blocks. There's a whole lot more to look at than that. Your schematic should show all ignition connections for every pack, every pair of trigger wires, every lead to the primary windings of each coil, kill wires from each pack, all grounds, stator wires to your rectifier...everything. If just one wire is on the wrong terminal or touching something it shouldn't it can be the source of your problem. You need a full schematic to look at so you can trace out each wire and connection.
