Mercury Ignition Coil Replacement for P/N 336-4528
WarthogMan
I just bought a 1973 Mercury 110/9.8 HP which has no spark. After testing the ignition coils, both primary windings are open so I need to replace them. The coils on the motor are P/N 336-4528 (the lime green type) but finding a replacement is tough because they are so old. There are a few on ebay but they look in pretty rough used condition and they are fairly expensive. Does anyone know of a newer replacement coil that will work and have about the same specs? It looks like there are plenty of 339 series coils out there at a reasonable price. If any of these could work, the part number would be helpful. Also, would I need to change the spark plugs? The motor currently has Champion L77JC4 plugs. I greatly appreciate any help and would like to get this motor running since it is pristine except for the ignition problem. Thanks
Amazon has a new one for $120.
https://www.amazon.com/dp/B00N6D93VU?tag=picclick0f-20&linkCode=osi&th=1&psc=1
Newer Merc 9.8 motors have a coil that is more avail, but just as pricey.
Coils are pretty tough. A used one probably works. A local salvage yard might allow you to exchange it if they sell you a bad one.
You could get your switchbox part number go on Sierra's web site and find motors with that switchbox and see what coil they use. I know the coil from a '73 Merc 850 and '77 Merc 1500 interchange, although they are different part numbers and size and color. They share switchboxes, stators and other ign parts.
WarthogMan
Thanks, Chris 1956. I found that coil on ebay also but I'm not sure I want to put that much into the motor, especially since I need two of them. There are plenty of new Mercury coils on ebay and amazon in the $15 to $25 range that have a similar shape and look like they will fit into the existing coil covers. I was just hoping someone out there might know which part numbers might be compatible.
Faztbullet
You have to use the lime green, red or orange coils as they are grounded internally different due to ignition system design. Newer coils will not work
WarthogMan
Thanks, Fazbullet. That helps. Does anyone know a good place to get the lime green, red, or orange coils at a reasonable cost?
