Mercury Powerhead Swap
delta07d
If I swap a Mercury 1973 1500 powerhead with one from a 1977 which years specs should I use? According to the manual I have the only difference is in the timing 1973 has 6 btdc for the throttle pickup - primary, 1977 has 1-3 btdc.
Or does this statement cover this?
" All of them are speced different, but if the 1st pickup hits at 3-4 degrees BTDC advance - you win"
Thanks!
Chris1956
Re: Mercury Powerhead Swap
A 1977 Merc 1500 Idle pickup timing is 4-6* BTDC. Not sure where you got your info....max advance is 21*BTDC. That outtake is likely from Clams Canino. It was general timing guidance.
